1 - 6 of 6 Posts
does it matter where the in/out oil lines goto? there werent any instructions. trying to finish up my bbk install, tips are appreciated
I don't have an oil cooler, but logic dictates it should cool either way. I say run the pump line in the top, and the return line out the bottom. That way gravity helps with the restriction of the cooler.
What oil catch can is that? I’m assuming that is what that is.
Where can you get one like that?
I don't have any help for ya but i am curious what you think of that cooler. I was looking into them and was curious what the difference in temps will be with it installed opposed to not having one. Lmk
The top hole takes the longer house route to the far left side. The bottom hole takes the shorter hose to the right side.
1 - 6 of 6 Posts
