1 - 14 of 14 Posts
Hey guys I've just purchased the protaper bars and was wondering if I want them the same width as the stock bars will I have any issues when cutting these. Bars to size and what's best to cut them
That's a personal choice, but if you decide to cut them, make sure there's enough left over to fit your controls/grip/etc.
Reactions: Chillis
Discussion Starter · #4 ·
Should I put my brake and other things on the bars without my grips on then cut them down 1inch at a time etc and use a hacksaw what about a pipe cutter ?
A pipe cutter will work, but it won't give you a flat surface. It's only something to worry about if for some reason the ends will be exposed.
You could put them on, then measure how much you have left to play with, etc. I doubt you'll have to gradually cut them, unless you want to see how they feel as you go.
Stock cables & everything fit fine
The bar ends won't fit the new bars though will they what do I need to buy for them to fit a guy on eBay said CYCRA GRIP ARMOR BAR END BLK but there £35 all together any cheaper ones that will fit
Picture of the bars on the bike?
I didn't use bar ends on my new bars. The new grips are closed at the end, so I just left them closed and installed.
Did you cut your's down or left them as they are.
1 - 14 of 14 Posts
