Do you guys have one?
I start my bike and then let it warm up as I put on my helmet, gloves etc....
As I am putting my gear on I walk all the way around the bike and look for things that might be coming loose. Just do a general visual inspection of nut, bolts and parts. Then I check to see that the turn signals are working as they should and I check that the brake light is working with both the front and rear brake. Only takes about 15-20 seconds for the inspection and then I am off.
About once a month or so I check tire pressure and chain tension (depending on miles ridden).
What do you guys do?
