Guys,
You need to read the other threads:
I can't do any dyno work without a fuel controller. I'm downloading a base map into the i-Map in about 10 minutes. At that point I'm about ready to go. So far the stock fuel injector is providing enough fuel for the system. Under load on the dyno, that maybe a different thing. It's been very cold & snowy here in the Milwaukee area, so I can't just go out on the road and setup the map, which I would normally do. I'm going into the dyno test a little blind, but it just means more time on the pump. The good news is that the piston has so far, been working perfectly.This guy is working as fast as he can.
Too much pressure, I can't take it!!!!
Just Kidding
Brian
