1 - 10 of 10 Posts
Could someone point me in the right direction. I've been looking all over and cant seem to find what I'm looking for. Every gauge I come across when I search for oil temp gauges ends up being cylinder head temp. I've found the tto oil temp gauge but cant seem to find an adapter to run it in the drain plug (which would be ideal for me) help would be greatly appreciated.
Discussion Starter #2
So far my findings are that the tto oil temp gauge (Here) paired with the koso oil drain plug adapter (Here) should be compatible and work if I'm not mistaken.
If someone could chime in and confirm thatd be awesome.
This is the only one to buy. Just one mans opinion though...
Make sure you get V2.
I infact seen them. However where does it actually read the temperature of the engine from? As I'm only looking for directly oil temp
Discussion Starter #6
Alright folks. Finally got the parts in last week and installed em tonight. Everything fits together and worked like a charm. Not a bad way to get actual oil temps as its reading directly from the sensor that's in the drain plug adapter. I'll keep ya all updated with how it lasts once I start to put miles on it. But I'm beyond stoked to be able to monitor my oil temps now for less then 70 bucks.
Make sure you have it on the correct setting....
1 - 10 of 10 Posts
