1 - 20 of 48 Posts
i didnt have a measuring cup, and i bought a 1 gallon bottle of motul 10w40.
i used the dipstick to check on oil levels, i kept adding more until i got to the notch on the dipstick.
the problem is i added too much. so now what do i do?
does the grom have a overfill so the excess will leak out on its own?
I like to have an empty quart bottle on hand for that. I mean how much over are we talking here?
Pop that drain bolt and try again or just run it. A tiny bit more oil isn't going to kill anything. Might be some added windage though.
southerngrom
the dipstick stem is about 3" long
the factory tip is on 1/8".
i filled it about 3/4" past where it is suppose to be.
should i use a turkey baster or something to suck it out?
If it was me, I would just drain it all and pour it again. It only takes a few minutes so why not.
Discussion Starter · #7 · (Edited)
Here is pic.
yes I'm a noob. I know they are coming so just good head. I can take it. (Don't get vicious)
when i I change the oil from my minivan. That is easy. Just put 5 quarts in.
i should have gotten a measuring cup!!!
Plumbing
You would want to drain a bit and try to fill again. Don't want to mess up the seals.
ok thanks guys... i will drain and try not to lose to much oil. and then refill.
off to sell my zuma... and i will attack this when i get home.
i will be near wally after the sale of the zuma. i will pick one up...
BTW guys... Motul 5100 is making my whole living room smell like a sour butter! it is all over my fingers.
Don't need a measuring cup, you need 1 quart of oil.
Reactions: RedWuken
This is why I prefer a sight glass to a dip stick. Dip sticks can be hard to read...not this on particularly though. It is a little different than other bikes where the actual oil level is such a small area and so low on the dipstick. I can see someone putting way too much oil in if they don't measure. It takes a bit less than a quart. You can take a plastic disposable cup like is used for soda and mark 2 cups on the outside, then just fill that twice. 4 cups equals a quart.
don't forget guy when checking the oil, you DO NOT screw the dipstick back in!
I kept finding 10w40 at the local stores nobody seems to carry 10w30 locally. I running the 10w40 also do you think that will cause a issue. I ordered Honda GN4 10w30 and dont plan on running the 10w40 long.
1 - 20 of 48 Posts
