1 - 13 of 13 Posts
I'm using a oil drain plug for a Nissan vehicle fits perfectly and doesn't protrude through the other side. I picked it up at autozone or oreilly's right off the shelf.
Sorry I don't know the number through the packaging away some time ago but it works perfectly. The package was clear hard plastic with the label being of green color. Said Nissan oil drain plug with a part number and the drain plug itself was gold with a washer.
Maybe that can help some.
I asked my local mechanic and he said I should just leave the original in place and disconnect the wire. No need to remove the OEM sensor and plug the hole.
If you're going to disconnect the OEM wire, might as well ground it.
1 - 13 of 13 Posts
