1 - 6 of 6 Posts
I've got a screetching noise coming from my bike when im WOT for a couple miles at a time. i have read a ton and only found one person saying changing the clutch collar fixes it. Because the noise goes away when i pull the clutch in. or someone has said its the bearing in the clutch cover. it really is driving me nuts.
My setup
2018 700 miles
dinger intake
zoom loop
tb cam and dhm tune
kitaco clutch cover
6 clutch springs
straight up pump
was the noise happening before you did the changes such as clutch springs or dinger intake.
I would first start with the clutch bearing by taking it out and putting back in with the bearing being flipped meaning what was facing the clutch plunger is now facing the clutch basket.
Good luck
put the stock clutch cover back on and remove the Kitaco clutch side cover, this will either eliminate the cover or not
1 - 6 of 6 Posts
