1 - 20 of 28 Posts
I was looking for an OEM style exhaust that eliminated the extra plumbing under the bike, which the stock system had. I decided to make the change now, while the various rubber parts on the exhaust were still new and supple. Everything went together well and if you like the look of the stock pipe, this system looks even better. It's slightly louder than the stock unit and I included some pictures of my bike with the new exhaust along with a short video (another Monkey owner) describing the system, as well.
If you're looking for a louder or different style exhaust... keep searching.
Land vehicle Vehicle Car Motorcycle Motor vehicle
Auto part Engine Vehicle Automotive engine part Motorcycle accessories
Tire Automotive tire Auto part Vehicle Suspension
The reason the stock headpipe winds around under the engine is that long head pipes produce more low rpm torque. The short head pipe of the Takagawa exhaust is for more high rpm horsepower which is what most riders want.
Hy, I installed the same Takegawa on my Monkey and like the result very much.
  • Idle - not louder at all
  • Ride - crisp sound, a bit louder but not loud. Just right
  • More clearance
  • Less weight
  • Cleaner look
@tooter , I read that more often that loss of torque should be one of the results in such a setup. For what exact technical reason do you think it should be like that? If it was a 2-stroke engine, I would agree with you.
But since it is a 4-stroke and the manifold has the same diameter, the exhaust gas velocity should remain the same and that is IMHO the important detail, not the backpressure. More backpressure reduces power from the engine since it has to work against that resistance.
Personally, I cannot feel a big difference in torque when riding the Monkey with the Takegawa.
Would really be interested in the technical details behind and finally ... the truth, if we're able to find it :)
regards, f r e d
Now what's needed is a heavy-duty skid plate that will fit with this exhaust. I have the KITACO unit but it's more for use with the "cat" and will require minor surgery to clear the head pipe so I'm going to just send down the road. I have a big slab of 1/4" aluminum so I guess I'll build my own.
I'll echo what everyone else said about the slight increase in noise and how perfectly it fit. It also has no packing to replace. Getting rid of the snake-that-swallowed-a-rat pipe gives you a LOT more ground clearance, too.
Be warned when installing the headerpipe - the Takegawa flange is half the thickness of the stock Honda unit and made of soft steel. Do not use the Honda (20ftlbs) or even the Takegawa (22nm) torque specs. You'll end up bending the flange and your header bolts. Nice product other than the cheap flange.
No they don't, the Stock muffler head pipe runs all the way down to the cat. so even if you bought an Akrapovic or Tyga. or. whoever's head pipe, you would have to cut and adapt at the stock muffler, and still couldn't use the front heat shield without more fabrication....I considered it, but ended up going Takegawa system and never regretted it..I see they are on backorder again from Japanwebike...good luck man
1 - 20 of 28 Posts
