Looks like MNNTHBX is about to release a quality set.
Id like to see a HOW TO on this with photos and all but mostly just for interest. I kind of doubt I would trust my skills to build brake lines. I will probably stick to buying some.I just put shadow series goodridge brake lines on they significantly increased stoping power and I just bought the lines and fittings and built my own for about 100 bucks for both front and rear. I can post a parts list tommorow ,i need to get the invoices and discreptions .
Maybe. I build and installed EVERYthing on my jeep except the brake lines. Did not feel comfortable bleeding a vehicle with four wheels although I have replaced the lines on several bikes with no problems. Actually crimping banjo joints etc.... mmmm no too sure about that.Rick , " You Can Do it......."
No crimping involved, they have lines you buy at specific lengths and the fittings screw in the ends,easy peasy. You can reuse your crush washers or buy a new box of ten for like five bucks( I like new fresh washers, in this situation). You can buy a break bleader from harbor freight for like 12 bucks that hooks to your air compressor and will pull the fluid into the new lines and get the air out . It really is quite easy. The only real pain was removing the right side fairing to get to the rear break resivour to add more fluid.the whole thing( frt and rear) 1 hour. Stoping power is fantastic,and the braking is very smoth.Maybe. I build and installed EVERYthing on my jeep except the brake lines. Did not feel comfortable bleeding a vehicle with four wheels although I have replaced the lines on several bikes with no problems. Actually crimping banjo joints etc.... mmmm no too sure about that.
Custom line with all Earls components would be SWEET though.
