Did not see a side cover in your mod list,,, If you are running your oil cooler straight thru the head bolt??? that is your culprit...
The TB 186cc cylinder has oil ports.Did not see a side cover in your mod list,,, If you are running your oil cooler straight thru the head bolt??? that is your culprit...
I've seen many run 5 or 7 row Oil Coolers, are the 3 rows just insufficient ?Yes adding clutch cover,,, either get some longer lines to connect to existing oil cooler or upgrade oil cooler.
I don’t see how running the oil cooler upside down would affect anything as long as the oil pump has the output to pump oil through the cooler. That has me thinking though.Yes adding clutch cover,,, either get some longer lines to connect to existing oil cooler or upgrade oil cooler.
Really not too sure if it matters but I believe running your cooler upside down like that might also affect it's proper cooling ability
Gravity feed so I would think upside down would not be as efficientSide Question: Should my oil cooler be installed with the in/outlets on the the top (pic included) of the cooler or bottom like I have it currently? View attachment 88383
