1 - 2 of 2 Posts
Hi guys,
I finally reached the end of my long noob neo kit build ! :)
87455
I didn't fail apparently as the bike start and can idle without any issue and I figured where the ticking noise came from ^^
I'm having one last issue that I can't pinpoint where it could be coming from :
When I give the bike some gas and let go, exhaust vibrates a lot for 1 sec and then goes back to normal.
When I ride and want to change gear, it does the same when I pull the clutch in and let go of gaslever
Is it normal? Do I have to worry about that?
Link is for video of the sound I mean
Exhaust vibration/weird sound
Discussion Starter #2 (Edited)
Also tachometer doesn't work anymore, I have no rpm on it, only have speed.
Where is the sensor for that? Anyone knows?
Tachometer wire (green/yellow) is plugged into ECU with the right pin on my EU Grom, I checked.
1 - 2 of 2 Posts
