I EVERYONE, I SEARCHED THE FORUM FOR THE ANSWER BUT NO POST HAS THE ANSWER IM LOOKING FOR. I AM TRYING TO CONNECT THE GREEN/YELLOW WIRE FROM MY TEMP SENSOR TO MY ANALOG PORT ON MY PCV, SO I CAN GET TEMPERATURE READINGS ON MY POD-300 lcd screen. THE PROBLEM IS THAT I HAVE TO KNOW THE VOLTAGE THAT THE TEMP SENSOR IS AT WHEN ITS AT A CERTAIN DEGREES. IM MAKING IT A 9 VALUE TABLE. SO VALUE NUMBER ONE IS GOING TO BE COLD AT 0 DEGREES FAHRENHEIT JUST NEED TO KNOW THE VOLTAGE FOR 0 DEGREES (PRETTY MUCH WITH THE BIKE TURNED ON BUT NOT RUNNING).
I DONT HAVE VOLTMETER TO CHECK OUT THE VOLTAGE IT IS RELEASING MYSELF. IF ANYONE HAS THESE VALUES IT WOULD BE GREATLY APPRECIATED.
