241 - 260 of 274 Posts
All buttoned up! Test ride went awesome, the close ratios of the 5 speed was what I was hoping for and more!
The Take 5 speed is very nice indeed, just wish 1st was a tiny bit shorter...
Looking at the pic I see you still have the stock O2 sensor. Is it there just as a plug or is it used?
Discussion Starter #242 (Edited)
You know, never considered the stock O2 sensor and what to do w/ it since switching to Aracer so long ago. I am using a wideband and the Aracer AF1 module to tune. TBH, not sure if the stock O2 sensor is doing jack, since the stock ECU is gone. I guess I didn't want to potentially throw a code - if that even is the case.
Right now running 15/34 with the 5 speed, gear 2 and 3 are insane, the engine spins up so fast that when you go from 1st to 2nd, and pin it, it revs so fast I almost thought the clutch was slipping the first few times. I swear is sounds eerily similar to VTEC. Can't wait to get my head ported.
I'm using the Aracer Mini 5 and replaced my stock O2 sensor with a plug. So far, no codes.
Discussion Starter #245
Discussion Starter #246 (Edited)
Taking the Grom where some say it shouldn't be taken - over 75mph. I'm sure the dude on the big bike had a good laugh when I passed him.
Merry Xmas everyone, ride safe and enjoy the Holidays with the ones you love.
Discussion Starter #247
It's almost summer, and after moving into a new place and time away from my Grom, I've got a few more upgrades planned in the very new future.
- MNNTHBX swingarm bushings - most excited for these.
- Race number plate - If anyone knows which LED lightbar will fit underneath perfectly let me know!
- Throttle body port - time to squeeze more power from my 4v.
- Renthal Fatbar Clamps - Using conversion risers right now, want the bar a bit lower and 5mm offset is welcome.
Then the plan is to ride it! Going to take it to Apex kart track once I get my shifting issues sorted out.
Debating the Yuminashi cam chain tensioner and flat timing chain, seems like a good upgrade for these high revving heads.
Here's a current picture of the bike:
Discussion Starter #248
A new project was started a few weeks ago, 2015 KTM RC390. It won't get too out of hand like the Grom build, I've promised myself, LOL.
The Grom is awaiting a longer Chimera swing arm bolt, with the swing arm bushings, the old one is too short for comfort.
Discussion Starter #249
Bike is running strong. No complaints. Knock on wood, I think I solved my problem of the bike shifting into neutral from 1-2.
Bike is due for an oil change, at which point ill pop off both covers for a cursory inspection. Entertaining the idea of the DROW 181cc BBK.
Right now, vibrations are the problem I'm tackling. The Hindle high mount does generate a good amount of buzz at the seat, and with the Saddlemens shape, it touched a part of my ass that it ends up making totally numb on longer rides.
Any tips on reducing vibes? I was thinking of rubber washers first between the can mount and the frame tab.
Discussion Starter #251
Curious at what you did to solve your shifting issues.
It ended up being the shift arm angle. Perfectly perpendicular to the ground ended up doing it. Making a 90deg angle with the shift rod and arm was my previous approach for some reason. I feel like it made sens in my head. Now that I also use GP shift, i find it much easier to apply positive force when shifting from 1 to 2.
Discussion Starter #252
Brembo 4P caliper purchased, time for a much needed upgrade to the stoppers.
Discussion Starter #253
Brembos fitted, just need a new banjo bolt and to bleed. They sure do look the business. Great deal at ~$130 to my door BNIB.
Discussion Starter #254 (Edited)
Bled the master and caliper to my satisfaction. First time bleeding my own brakes, no mityvac used. Was pretty challenging to get good lever feel.
But - the stock master is totally up to the task. I am using SS lines. Great modulation and firm feel.
I think the Brembo caliper looks AWESOME!
Discussion Starter #255
Brembo P34 and BRAKING rotor installed. Hope this brake line routing isnt an issue!
You will be the first to know if it is an issue!:toothy9:
What is the benefit for running the rear caliper on the bottom? Is it primarily for lowering the center of gravity? It just seems very vulnerable to damage.
Discussion Starter #258 (Edited)
No benefit, it just so happened that the cheapest P34 rear adapter on SteadyGarage was a bottom mounted design. It looks like a copy of the TYGA design.
I was unsure of how I would like the look - but it looks pretty cool. It is a lot more exposed down there...
Discussion Starter #259 (Edited)
Latest updates: G-Craft damper bracket and some cheap Chinese Z900 damper kit. It comes withe the Stage 3 Hyperpro style clamp so everything lines up. Damping adjustment works, only time will tell if it doesn't corrode or leak prematurely.
Rear brake finally bled with the help of a bleeder banjo bolt. Love the look of the underside caliper now.
Type B number plate installed. It looks meh where I mounted it...would look better with the OEM speedo shroud.
I do like how the angle of the plate matches the side fairing. It looks quite angular and sporty.
Next up is a proper wide 7/8 bar since I have to use the OEM bar mounts with the G-Craft damper bracket.
Was difficult to find neutral with the short arm included with my rearsets so I've just swapped out to a longer one. Will see how it shifts. I've left it perpendicular to ground as well for now. 90/90 is what I've done on the Duke but that's really my only reference. It does work there though.
