The KOSO DB03R is not "plug&play" . This is how I did it ;
Connect Honda (H) Yellow/white - Koso (K) Green . ( Fuel input and has to be set at 250 Ohm ).
H Oranje - K Oranje . (Turn left)
H Light green Red - K white (neutral)
H blue - K yellow ( High beam )
H Light blue - K blue ( Turn R)
H Red Yellow - K Red ( batterie 12V )
H Black - K Brown ( Ign switch )
H White blue - K Purple ( motor amber warning light )
H Green Black - K Black (Ground)
H Green - K White black ( speed sensor ground )
H Pink - K Blue Red ( speed sensor power )
H White Red - K Blue White ( speed signal ) Tip ; You can connect the White Red speed signal at the same time to your Power Commander speed input. It will see your speed and Gears and from now you can make different maps for each gear.
I did not connect the H Yellow Green with the K Brown Red ( RPM ). Instead I have used the included cable connector to the ign. coil and ground.
I have used an optional Koso 10mm temp sensor and placed it where the original sensor is mounted ( first drain oil ).
The original LCD connector is still working , can switch it back in no time or can connect both LCD's at the same time for callibration.
It has a Voltmeter with warning , Temp. with warning , 2 shift lights ; yellow and red , Gear indicator , time functions , 3 RPM ranges ;10K , 12K and 15K , 3 display colors ;oranje, blue and purple, speed warning , ...
Used parameters ;
Speedometer : A6 0300 12P (for example , when you set it at A6 0300 13P your speedometer wil read lower speed ).
RPM : A7 Hi Act P-0.5 (using included cable connected at + coil and ground).
Fuel : A9 250.
See pictures :
Used parameters ;
Fuel : A9 250.
See pictures :
