1 - 8 of 8 Posts
Hi, someone know what are the specs of the cam in the kitaco neo 181 BBK? I ask because after install I need top start tune using the Power Vision and this info can help me to find a closes tune to start from.
Thanks in advance, regards
Dariusz W.
Ask the vendor who sold you the bbk?
You need to ditch that PV and get an aracer and do it right, the 2nd time in your case.
Ha ha ha is a little expensive do a change now, PV is what I have and like to use. Whit the cam info I can be close to a first start map so I can only adjust and be good for the NEO
DJ offers a base map for the NEO kit. It uses the stock throttle, but you should be able to rescale TPS column values to something workable.
Look in your Installation Manual wich comes with the Kit, Camshaft Timings are provided by Kitaco.
I am sorry but Wicked_VFR is right, ditch the PV and get a Aracer Mini 5 with the AF1 AFR Modul.
I am running a complete Neo Kit with 34mmTB, Hindle Exhaust and all the supporting Mods, i have tried everthing to get the Bike run well with an PCV/WB2,
search for my Posts here in the Forum, drove around 600 miles to build a Map but never got it runing perfect. After installing the Aracer Mini 5 / AF1 the Bike ran
instantly better, building the Map only needed around 1hr riding Around.
I've been running the PV3 (NOT the PCV) for under 50 miles and it idles fine, runs fine, and the map is dialed in. Sounds a lot like user error - 600 miles to tune a single cylinder motor is insanity. aRacer and PV3 are both fine choices. I would not personally run a piggyback box such as the PCV. For reference, I'm using the a 32 mm ported throttle from a Honda Streetfire (old model); the only issue I had was the stock battery not being strong enough for the 181 kit.
1 - 8 of 8 Posts
