So as most of you know already, I installed the Kitaco 164 piston and cylinder along with Daniel Crower cam, modiferceret t/b 26.5mm, pcx injector, and Api tech EFI advance. The first couple of rides were fine as I could adjust the fuel do to bogging or bucking to either lean it out a little or fatten it up. Today was my first long test ride. About 20 miles one way then back. I rode this morning to work and about half way there with an outside temp of near 70 the bike started to bog just cruising. If I hit the throttle to try to clean it out it would just go slower. After I came to a stop and started again it only did this 2 more times the rest of the way to work. So before I left to come home I richened it up quite a bit on all settings and turned the ignition back to stock. After 5 min this started again. I pulled over almost 5 times trying to get the settings right but nothing seemed to help. I finally noticed some spark knock when it would start happening. So i just limped it home easily as not to damage anything. When I got home I laser temped the head and it was at 305F. I assume this is a timing/heat issue and I know that no matter how much fuel I added or took away it didnt seam to help. Any idea on what i could do to fix this?? The cam timing is dead on and tuner is set at stock timing.
Thanks in Advance,
Daniel
Thanks in Advance,
Daniel
