1 - 1 of 1 Posts
How’s it going guys so I have a 2018 Honda grom. The bike was stolen and when I got it back they had punched out the original ignition with a flat head to break the steering lock and then had a bypass ignition switch plugged into there the ignition plugs into the wire harness and started up no problem but it was just janky looking so I got a new ignition, replaced it and when I go to run on the bike everything turns on except for my head light and it won’t turn over or start at all, also I don’t see the check engine light go on for that split second when you turn it on so I was curious if anyone knew what I should do. I thought maybe it was in a auto theft mode so I tried resetting the ECU but I couldn’t get the check engine light to blink or even turn on at all. Any advice is greatly appreciated thanks for your time!
1 - 1 of 1 Posts
