1 - 20 of 60 Posts
wheelie practice the 1st week i got the Grom!!
SPECS:
ENGINE: stock, Crower cam, steady garage lightened oil spinner & flywheel, custom air intake w/ K&N filter
TRANSMISSION: JT front sprocket 16T, PMP rear sprocket 36T, DID gold chain, titanium blue sprocket nuts
IGNITION: Nology coil, Nology hot-wires, NGK iridium plug
SUSPENSION: ohlins rear shock, takegawa fork adjusters, Gcraft triple square swingarm +6cm, Scott steering damper
ELECTRONICS: bazzaz efi, DOMINO starter kill switch
EXHAUST: Yamamoto full system
WHEELS & TIRES: michelin power pure SC, RRGS orange valve stems, Tyga aluminum wheel spacer kit
LIGHTING: PETEX headlight, Steady Garage front turn signals, MNNTHBX intergrated tail-light
BARS: Driven SBK euro bars, MNNTHBX bar stem with SCOTTS damper, DOMINO grips, Motion Pro revolver throttle kit
PROTECTION: Driven bar ends, OVER racing engine sliders, Rizoma brake lever guard, H2C axle sliders
ACCESSORIES: H2C smoke windscreen, TYGA CF tank cover/instrument cover/round side covers, H2C gas lid CF overlay, Yoshimura engine plugs, LighTech oil cover
REARSETS: Driven rear sets
BRAKES: Tyga brembo adapters, brembo gold calipers, CORE MOTO brake lines, HRC rear brake SBK reservoir, ASV C5 levers, Tokyo Parts brake reservoir cover
BODY: Tyga CF tail cowl & under cowl, tyga front fender, Steady-garage decal kit
this is how she sits for now
H2C side vents that dont do anything, just looks!!!
TYGA bar clamp, CF tank cover, CF meter cluster, H2C gas lidCF overlay
Pro-Taper 7/8ths bar for KLX/DRZ, 1" lower than stock, removed 1 1/2" on each end
TDM headlight and smoke wind-screen
TYGA CF parts
TYGA CF parts
ASV C-5 lever from 2011+ cbr250, DRIVEN grips and bar ends
hotbodies LED smoke flush mount turn signals from 2005+ cbr600RR
nothing but the best, Ohlins rear shock, built really solid, noticed the difference on the 1st ride, smooth and not to stiff!!
gcraft swingarm
yamamoto full exhaust system
with tyga shroud
custom air intake by BigChris, thanks for goin turbo and letting me rock this!!!
tyga CF shroud with a MILD touch!!!
MNNTHBX lightly smoked!!!
BREMBO's safety wired
Grom at Motion Pro for R&D
First Grom with Motion-Pro Revolver kit
1st long ride to Santa Cruz
Moto3 inspired race graphics, thanks to Steady-Garage for making me the graphics i visioned in my head =)
Motochamp July #7
2 page spread of #supergrom
like!
Nice turns. Do they just fit? No mod needed?
yea, they just fit, its a perfect fit, it matches the factory shape of the grom, u just need to add small spacers in between the inside gap and a big spacer after and tighten down the nut!!!
Looks good, wish I could wheelie like that.
Looking good.
Are the Tyga CF parts secured by fixings or just stuck on?
I really like the levers
The tyga CF parts are just double taped on, for some reason they didn't provide enough 3m double tape , I went out and bought more!!
Discussion Starter · #15 ·
niiiceee, how's it ride ??
finally got to test out the rear shock on some twisties and bumpy rd, the shock is definetly better than stock and responds and handles well, its more stiffer for sure cause of the spring, i tried playing with the compression too, im at 12 clicks from soft, theres a total of 24 clicks so im at the middle since im fairly a light guy...
Discussion Starter · #16 ·
some new updates
yamamoto exhaust
installed on the bike,this pipe is bad ass!!!
gcraft triple square swingarm 2 1/4 " longer than stock, PMP 36t rear sprocket, DID 120 gold chain with blue titanium nuts
How'd you get the rear reservoir to work? I bought the same one and it seems loose on mine. Show a full pic!!! Lol
I told you that you would like the Yamamoto. I love mine! Can't wait to see your bike finished!
Discussion Starter · #20 ·
are u talking about the rear brake reservoir, its an HRC kit but its nothing special, i couldve made my own, i cut it really short maybe thats why its not loose....
1 - 20 of 60 Posts
