I have a question concerning intake modifications.
My question specifically is which is better :
Modded airbox ( I believe this to be the best solution for an intake being that the cylinder is right below the intake and has a high probability of causing heat soak)
Or a dinger built intake - the longer one
And I mean specifically in real world applications where throttle position is very greatly and the bikes will be running hot due to high rpm use.
I suspect that in real world application the modern airbox would be superior due to its ability to flow more air that is specifically cool while maintaining a Plenum of air which will allow for greater power when varying throttle.
what’s your .02
what’s your .02
