My old Yuminashi stand alone ECU did that too.... I had to unplug the cold start to make it go away. Not sure if bikes in the Netherlands have a cold start solenoid like USA bikes though.
My bike also Hase the cold start lemme find that plug and il try it thanksMy old Yuminashi stand alone ECU did that too.... I had to unplug the cold start to make it go away. Not sure if bikes in the Netherlands have a cold start solenoid like USA bikes though.
I unplugged that sensor and it stopped ticking thanks!!!My old Yuminashi stand alone ECU did that too.... I had to unplug the cold start to make it go away. Not sure if bikes in the Netherlands have a cold start solenoid like USA bikes though.
Happy to help, 🍻I unplugged that sensor and it stopped ticking thanks!!!
What's your thoughts on the Yumi ecu? I have a 181 kitaco and I have something plug and play and tired of messing around with fuel controllers.My old Yuminashi stand alone ECU did that too.... I had to unplug the cold start to make it go away. Not sure if bikes in the Netherlands have a cold start solenoid like USA bikes though.
Wouldn't recommend it..... Only reason I bought the one I had was it was CHEAP & at he time there weren't many reliable options available thqt gave full control over the bikes parameters...... Different story now. I have switched to aRacer MiniX & AF2 wideband on mine. Bike runs perfect after getting it set up & some base maps made. It autotunes & I really do not need to mess with it unless I want to....What's your thoughts on the Yumi ecu? I have a 181 kitaco and I have something plug and play and tired of messing around with fuel controllers.
