Today i decided to experiment with my analog output to see if I could get it to work with the stand alone ECU. To my surprise it works great. This is great news and is really easy to hook up.
First take your analog output wire from your AF meter (most have one), in my case the yellow wire coming from the back of my NGK AFX and plug it directly into the plug for the o2 sensor. I just used the female end of a bullet connector which works great.
Next go into the yuminashi software under the setup tab and then click on "oxygen sensor characteristics setup".
Once this screen pops up enter the values provided by the manufacturer of your Wide band AF meter to define the parameters. Make sure you go from 5v to 0v from left to right, which seems backwards, but is how it needs to be done. Afterward enter the corresponding AF ratios to those voltages.
I used this chart for mine: http://www.ngksparkplugs.com/pdf/AFX_Linear_Output_Chart_6-07-05.pdf
Once you are done press "enter" on your keyboard to send the data to the ECU. Now the meter will not only read your current AF ratio, it will log the data in the AFR monitor tab by automatically putting the values into the table making tuning way easier.
Here is an example with the engine running, the engine is cold here and i still need to adjust the enrichment values under the enrichment corrections tab so it runs leaner when the engine is cold, but this gives you an idea of what it can do.
I am loving this ECU and and its capabilities. Ill make a video on how to use the software soon and get it posted.
