Done!
There are two options to solve the problem:
1. Turning off the sensor. Between contacts of the plug set resistance from 500 ohms to 800 ohms (520 ohms at me). Voltage, resistance after installation, between conductor and earth red (-) must be greater than 5.6 V, if less, then put a slight resistance.
2. Turning off the sensor. Carefully remove the white plastic and take out a small bowl. Then collect all back. The method has not been verified, but should work.
