1 - 3 of 3 Posts
Hello grommers,
I am trying to open right crankcase cover to clean 'engine strainer screen' and 'engine oil centrifugal filter'.
To open right crankcase cover, the right step must be dettached
but it is stuck on swingarm pivot
Automotive tire Motor vehicle Automotive lighting Motorcycle Wheel
Automotive tire Motor vehicle Electrical wiring Gas Automotive fuel system
Any good idea to solve this problem?
I am doing this work with zillafullboost's youtube
You can get the cover off without removing it, but the stock exhaust might need to be dropped.
Otherwise the set should come loose with the nut and bolt removed, and make sure the exhaust hanger bolt is removed too.
I would place a wood block under the exhaust if you have a sftermarket exhaust to support it while the rear set is removed. The stock exhaust is bolted under the engine so does not need any support while rearset is removed. Once you do manage to get it off put some antiseize on the bolt so next time it wont be an issue.
1 - 3 of 3 Posts
