1 - 20 of 21 Posts
Ok, here it is.
Installation of the SBL Double LED Light Bar Headlight Conversion.
Very easy to do.
Takes about 20-30 min, the first time around to do the install.
Probably would only take about 10-15 min to go back to stock, if you need to.
Looks great, works great........ and of course, Bright as S$%T.
Can't ask for much more then that. :)
Click here for FORUM SPECIAL >> GROM PARTS CATALOG <<
Love the video! Glad y'all did this and SBL didn't have to take mine away from me to make it:)
for or anyone that's interested in this setup, it truly is amazing at night and lights up the road in front of you and the other lanes as well which is real nice for turns and being able to spot out sand and garbage in the road. Nobody that I know likes to dump the front because sand in the road and I will say this one has saved me a time or two on unknown roads at night.
I am considering this or the HID kit, good video, very informative
+1 to what Floppy said.
The HID kit is a great upgrade.
But, the Double LED Light Bar conversion is another 3 steps up over that.
It's Like turning on the sunlight.
call me a noob, but i just read another post that red/blue headlight is illegal.
In the video, it was mention that it very easy to remove it for those are concerned about yearly inspections...
In texas, is there a law that i need a hi beam? what makes this setup not pass inspection in some states?
Discussion Starter · #7 ·
Well, this LED is PURE WHITE...... so no worries there.
Some States, require an annual inspection. And sometime they require a high/low beem.
So, if your state is like that, then you would just swap back, once a year.
If your state does not inspect..... then you are all good.
anyone good at intrepeting these things???
I think, i'm covered under Section B. I can have a single beam.
And again it restates it in section C-2.
So at least in Texas, i will be fine...??
SUBCHAPTER M. ADDITIONAL OR ALTERNATIVE EQUIPMENT REQUIREMENTS FOR MOTORCYCLES AND MOTOR-DRIVEN CYCLES
Sec. 547.801. LIGHTING EQUIPMENT. (a) A motorcycle, including a motor-driven cycle, shall be equipped with:
(1) not more than two headlamps mounted at a height from 24 to 54 inches;
(2) at least one taillamp mounted at a height from 20 to 72 inches;
(3) a taillamp or separate lamp to illuminate the rear license plate that complies with the requirements of Sections 547.322(f) and (g);
(4) at least one stoplamp that complies with the requirements of Section 547.323(d); and
(5) at least one rear red reflector that complies with the requirements of Section 547.325(b) and may be included as a part of the taillamp.
(b) A motorcycle, other than a motor-driven cycle, shall be equipped with multiple-beam lighting equipment that produces:
(1) an uppermost distribution of light that reveals a person or vehicle at a distance of at least 300 feet ahead; and
(2) a lowermost distribution of light that:
(A) reveals a person or vehicle at a distance of at least 150 feet ahead; and
(B) is aimed so that no part of the high-intensity portion of the beam on the motorcycle that is on a straight and level road under any condition of loading projects into the eyes of an approaching vehicle operator.
(c) A motor-driven cycle shall be equipped with:
(1) multiple-beam lighting equipment that complies with the requirements of Subsection (b); or
(2) single-beam lighting equipment that:
(A) emits light sufficient to reveal a person or vehicle:
(i) at a distance of at least 100 feet when the cycle is operated at a speed less than 25 miles per hour;
(ii) at a distance of at least 200 feet when the cycle is operated at a speed of 25 miles per hour or more; and
(iii) at a distance of at least 300 feet when the cycle is operated at a speed of 35 miles per hour or more; and
(B) is aimed so that no part of the high-intensity portion of the beam from the lamp on a loaded cycle projects a beam higher than the level center of the lamp for a distance of 25 feet ahead.
(d) A motorcycle may not be operated at any time unless at least one headlamp on the motorcycle is illuminated. This subsection does not apply to a motorcycle manufactured before the model year 1975.
Acts 1995, 74th Leg., ch. 165, Sec. 1, eff. Sept. 1, 1995. Amended by Acts 1997, 75th Leg., ch. 782, Sec. 1, eff. Sept. 1, 1997; Acts 1999, 76th Leg., ch. 1022, Sec. 1, eff. Sept. 1, 1999.
Looks like in texas, Section B, states Red is defeintely a NO NO... :)
Ready for my LED headlight!!!... just hope the weather clears up next so I can go out and ride soon!!!
Sec. 547.305. RESTRICTIONS ON USE OF LIGHTS. (a) A motor vehicle lamp or illuminating device, other than a headlamp, spotlamp, auxiliary lamp, turn signal lamp, or emergency vehicle, tow truck, or school bus warning lamp, that projects a beam with an intensity brighter than 300 candlepower shall be directed so that no part of the high-intensity portion of the beam strikes the roadway at a distance of more than 75 feet from the vehicle.
(b) Except as expressly authorized by law, a person may not operate or move equipment or a vehicle, other than a police vehicle, with a lamp or device that displays a red light visible from directly in front of the center of the equipment or vehicle.
(c) A person may not operate a motor vehicle equipped with a red, white, or blue beacon, flashing, or alternating light unless the equipment is:
(1) used as specifically authorized by this chapter; or
(2) a running lamp, headlamp, taillamp, backup lamp, or turn signal lamp that is used as authorized by law.
(d) A vehicle may be equipped with alternately flashing lighting equipment described by Section 547.701 or 547.702 only if the vehicle is:
(1) a school bus;
(2) an authorized emergency vehicle;
(3) a church bus that has the words "church bus" printed on the front and rear of the bus so as to be clearly discernable to other vehicle operators;
(4) a tow truck while under the direction of a law enforcement officer at the scene of an accident or while hooking up to a disabled vehicle on a roadway; or
(5) a tow truck with a mounted light bar which has turn signals and stop lamps in addition to those required by Sections 547.322, 547.323, and 547.324, Transportation Code.
(e) A person may not operate highway maintenance or service equipment, including snow-removal equipment, that is not equipped with lamps or that does not display lighted lamps as required by the standards and specifications adopted by the Texas Department of Transportation.
(f) In this section "tow truck" means a motor vehicle or mechanical device that is adapted or used to tow, winch, or move a disabled vehicle.
Acts 1995, 74th Leg., ch. 165, Sec. 1, eff. Sept. 1, 1995. Amended by Acts 1999, 76th Leg., ch. 380, Sec. 1, eff. July 1, 1999.
Amended by:
Acts 2011, 82nd Leg., R.S., Ch. 229, Sec. 3, eff. September 1, 2011.
Motorcycle inspections tend to have a lot of wiggle room so to speak, especially at a customs shop. Technically stuff like fender eliminators, non stock blinkers, and exhausts should make a bike fail but nobody cares.
Sent from my DROID RAZR using HondaGrom.net mobile app
Easiest way to say this is a cop that pulls you over for that and actually gives you a ticket is BS. You would get a fix it ticket which would be a non moving violation so you'll be ok:) plus when has anyone ever been pulled over and the cop ask you to see of you have a high and low.
Exactly.
Sometimes you can worry too much about things. ;-)
Discussion Starter · #14 ·
Sorry to bump an old thread, but just wondering how these are doing long term. Also how well the low/high function works now.
Happy to report we have sold over 100 + sets in past year... Zero failure .
Love mine, zero issues. I haven't had a single charging issues either, which Led are easier on battery anyway. Have my main low pointed fairly toward the ground. still lights up everything in site. just keeps the beam from blinding people. when I hit the highway or bypass here, I flip to the high beams where they are pointed straight out pretty much. They are so amazing. Have helped me see idiots walking / skateboarding / biking in the middle of the freaking road at 2am. Really lights up construction areas in town. People see you coming and you see them ahead. I love it as extra safety on this little bike.
Discussion Starter · #16 ·
100% Agree.
The added bonus is definitely, that Cars you see better.......... day and night. They can't miss those lights.
Where as the stock is soo dim, it's easy to miss.
It is so weird that some users have zero charging issues while others like me have all kinds of problems!
but there aren't too many problems that can't be fixed once you throw money at it. My hi output stator from ricky stator should be here today.
If anyone is interested, sometime in october I will be putting my SBL lights up for sale. I'm getting some rigids sr2's.
Discussion Starter · #19 ·
I'd be interested.
Is there a way to wire the lights so that the low beam light and high beam light stay on together with the high beams on?
Yes, all you need is a Diode in the Power Wire for the High Beam.
That way, when the low beam is on...... only the lower light bar is on.
Then you flip the high beam, and BOTH Lights come on.
1 - 20 of 21 Posts
