So I hated the way the horn hung down below the headlight and wanted to clean it up. So here how to make a slick horn mod with no extras. When you look at the Horn mount on the back of the lower fork clamp it has a 10 mm hex head , take that loose( put a rag on your front fender so you don't get any scratches ).Now unscrew the nut on the back of the horn itself ,take that bracket and toss it. Now follow the wires for the horn to the front part of the lower fork clamp,there you will find a 6mm bolt with a 8 mm head( I used an open end wrench between the fork and headlight housing)take that bolt out and press the tabs on either side of the plastic clip that is attached to the bracket you just loosened up by removing that 6 mm bolt . Now that little bracket is the key, I used my vice and set it in the jaws on it side so it looked like a v facing up and proceeded to close the vice untill it was flat. Then you take the 6 mm bolt and the flattened bracket ,when you install it ( I did it from the right side) face the bracket so the lower L shape piece with the larger of the two holes facing the center of the bike. Install the 6 mm bolt through the bracket and into the front part of the lower fork clamp.Then install the horn onto the bracket you will see that it fits very nicely into the backside of the lower headlight housing without effecting the tone or volume of the horn. It looks super clean and I was stoked to figure it out. I have pics but not sure how to post them
