1 - 6 of 6 Posts
Wondering if a high output coil would be worth the Money. Like a Kitaco xr /crf 50 coil Hopefully the bike will be in by September. I know I will be addIng a pipe probaly the Moriwaki down pipe.
I read a few things about cutting some vents in the air box then resetting the computer by disconnecting the battery. Plan on keeping the motor stock for a while but will be putting in a big bore kit later.
Just wondering what I can use now and later when I put the Bbk in.
Do you think a 33 tooth rear sprocket will help now then bump up the front sprocket one tooth after I put the motor kit in.
Thanks
Looks like I'm saving money tonight. It's a good night.
Thanks
1 - 6 of 6 Posts
