1 - 13 of 13 Posts
For those of you who have done a HID install, what is your idle voltage? I'm using a 35W ballast and my voltage at idle dips to 11.9v. the grom is ridden almost daily so the battery should be good. i'm currently doing a trickle charge overnight to see if that helps.
I have had a hid for a months and no charging problems I have not charged it once, my voltages is the same at idle .. , and its been riden almost every day... As long as you don't idle the bike for hours you will be fine ( actually drained battery longtime ago tuning and idling a lot ,I had to bump start the bike but with a mile down the road was already charged enough by the stator to start the bike). As soon as you rev the bike the voltage should go up.
Discussion Starter · #4 ·
my voltage does start to increase above 3000 rpm and eventually surpasses 14v. just not sure if the low idle voltage is normal or if i have a fault somewhere.
Where are you tapping the Hot voltage from, the rear tail light HOT wire or ??????
taping switched 12v from the rear tail light which triggers a time delayed relay. the relay is wired to the battery (fused) for it's source of power.
btw, i'm measuring the voltage across the battery terminals.
You are over thinking this, i bet your grom is 100% fine....... if the battery dies which it "WONT" then i would worry about this...... Just ride the grom like you stole it and dont sweat the small stuff.....
Discussion Starter · #10 ·
my double led bars also i believe have a high draw... i have unplugged the relay during the daytime, and hadn't needed to charge my battery at night.
the days i leave the relay connected so that my headlight is ON, if i dont trickle charge it overnight, within 2-3 days... i will be bump starting my grom.
annoying, and i haven't figure out a way to fix it
1 - 13 of 13 Posts
