I would go with the the below. Under $20 and "they" say the beam style are accurate for longer. Your right - clickable are hard to find sub 10 ft/lbs, as I believe that is a whole different wrench that measures in inch/lbs.
I've heard that finger tight + 1/8 a turn gets you approx. 7 ft/lbs.
Craftsman 3/8-in. Dr. Beam Style Torque Wrench, 0-75 ft. lbs.
Item# 00932999000P
Or
Craftsman Micro-Clicker Torque Wrench 3/8" Drive
Item# 00931424000P
PS the clickable is on sale for like $36 which is more than half off. I would get that one with 3/8 drive and 10-75 lbs. I have one and If I remember correctly you can set it slightly lower than 10 ft/lbs. I will check when I get home.
Item# 00932999000P
Or
Item# 00931424000P
