1 - 5 of 5 Posts
Hi, I am having a lot of issues installing the Brembo RCS14 to my Grom, did anyone use the same master cylinder RCS14? If so can you please show me some pics of your brembo RCS14mounted?
Maybe, let me know what my issue is seen here:
Thank you in advance!
This is my setup with a magura master and RSC clutch perch.
Bicycle handlebar Vehicle Automotive tire Bicycle Automotive lighting
Bicycle handlebar Vehicle Automotive tire Bicycles--Equipment and supplies Bicycle
Tire Bicycle Automotive tire Light Bicycle frame
I also used a dominator clutch cap with brembo linear master. That unit is for sale if you want to try it.
Bicycle handlebar Plant Bicycle part Vehicle Saw
Wood Yellow Rectangle Material property Automotive exterior
Motor vehicle Bumper Wood Automotive exterior Gas
Vehicle Automotive tire Automotive lighting Motor vehicle Fuel tank
Automotive tire Automotive lighting Motor vehicle Vehicle Automotive design
Thank you, very helpful to see!...just trying to make my set up work. Guessing a RSC lever might fix it due to the adjuster?
Looks like that large adjuster is causing problems. I would just remove the large locking ring and keep the smaller inner cable guide.
You don’t really need a locking ring. Adjustment will stay put.
Keep us posted.
Yeah, some guys said it's actually my xr50 bars...so I ordered the klx 110 bars which offer more space for the control area. I'll let you know if it did the trick! Thx!
1 - 5 of 5 Posts
