1 - 2 of 2 Posts
I have a 2018 Honda grom and the problem I’m having is I can’t put it into first gear at a stop. Like I’m regularly driving it going through the gears and then I shift down at the stop and the clutch lever goes down and I release the clutch but the bike doesn’t go forward basically it is in neutral. Please help I’ve searched everywhere and no help. Thanks I’m advance
2020 Honda Monkey and others
Make sure your chain has the proper tension. An overly loose chain can cause this.
Another thing you can do to help get into first is to roll the bike back or forward a little with the clutch in while trying to shift into gear.
Also make sure your clutch freeplay is set correctly.
1 - 2 of 2 Posts
