1 - 20 of 24 Posts
I bought my 2015 used with only 363 miles and an LED headlight kit.
I found a great deal on a used Yoshimura RS9 exhaust and used the forum discount to order a bunch of other parts from Drowsports.
I added:
TST Industries Flushmount Turn Signals - Clear
TST Honda Grom Front Turn Signal Converters 3 to 2
TST Industries 2 Pin LED Flasher Relay
DROWsports Carbon Fiber Intake, K&N Filter, & Fairing Rod
Hot Bodies Honda Grom Fender Eliminator
From Partzilla:
CB1000R Mirrors
Buttdyno says everything is faster! Hahaha.
Next weekend is an oil change and installing JT Sprockets Honda Grom Sprocket, Front 14t
Sato Racing Honda Grom Shift Spindle Support (Gold)
How do you like that intake. I've been looking at getting it for a while but havent heard much about it
I like the sound of it paired with the exhaust. It is loud when you're at full throttle though. It doesn't bother me. There was a thread about the sound a couple days ago that's worth checking out, if you're worried about it being too loud. Everything does feel a little faster. The one thing I have to check out this weekend is that the fork will tap the K&N filter when I turn the wheel all the way to the right. I may have to just recess the filter a bit more, so that doesn't happen. Make use of the forum discount that Drowsports gives. SPEND!!!
Edit:
Here's that thread:
Drow Sports Carbon intake - Screaming banshee!
I got the TYGA lower cowl from @steadygarage. They gave me great customer service and a discount for being a HGN forum member. The cowl looks great on the Grom. The color was pretty close to OEM. It was easy to install, but took a bit to get into the right position. It's a tight fit and is touching the engine in a few places. The cowl was warm when I got into work, so I'm going to dremel down any of the contact points the next time I take it off.
14t front sprocket installed and had to readjust the chain. It had so much slack after putting in the sprocket. The chain was like a limp noodle.
Did it's first Oil change, and oil spinner cleaning. Replaced the original gaskets. The original crank case gasket was stuck to it, so I had to razor blade that damned thing off.
I learned that the Yoshimura RS9 blocks access to oil drain bolt and had to undo the bottom part of the exhaust to get it to move over enough. Anyone install a fumoto oil valve on their Grom? Which one did you get, if you did? I have it on my cars and it makes oil changes clean and easy.
Lastly, I tried to install the shaft shift support from Drowsports, but I couldn't get the lever off. It would get about half way off the spline then stop. I didn't want to force it and ruin the splines. Anyone have tips on how to get it off, without removing the rearset? I plan on doing the shift linkage mod and put it on then. Hopefully the lever will come off when it's not attached to the linkage.
Discussion Starter #7 (Edited)
I did my first valve adjustment on the Grom the other day. The one thing I wish I had bought would have been the TAPPET / VALVE ADJUSTER TOOL, 3MM SQ., W/9MM SOCKET WRENCH. I did it with needle nose pliers and a 9MM socket, but the tappet would have made adjusting the valves a breeze.
Just an FYI, the Valve Clearances are:
IN: 0.10 ± 0.02 mm (0.004 ± 0.001 in)
EX: 0.17 ± 0.02 mm (0.007 ± 0.001 in)
I finally was able to install my Sato Racing Honda Grom Shift Spindle Support Bracket and do the Shift Linkage mod. They seem to have helped my third gear not engaging issue. It happens still, but not nearly as frequently. I think I need to shift into 3rd closer to red line. Finding neutral is easier now too.
For the linkage I bought these off Amazon:
QSC CMR-5, 5/16 X 5/16-24 Economy Male RH Rod End
QSC CFR-5, 5/16 X 5/16-24 Economy Female RH Rod End
and this nut to get free shipping: QSC 5/16-24 RHJN, 5/16-24 Steel Right Hand Jam Nut, Clear Zinc Plated
I didn't use the nut. I also had to cut the Male Rod End down nearly in half to make it the proper length when mated to the Female Rod End. I put a lot of Red Loctite on the threads to keep everything in place
For the nuts and bolts to hold the linkage together, I bought these from the DIY center:
(2) 1/4-28x1 bolts
(2) 1/4-28 hex nuts
(4) M6 Flat Washers
I put Red Loctite at the ends and Voilà, linkage completed and all for about $10. I added this info to the Shift Linkage thread too.
I installed POWTEC PT-GROM Adjustable short Brake and Clutch Levers. They’re a little shorter than stock and seem to be decent quality. Here’s a comparison of the brake lever:
Finally, I was able to install the black powder coated rear sets I bought from @BLKGRMRR.
I also picked up the MNNTHBX Faux Frame Cover. I love the black look on the lower half of my Grom now.
Discussion Starter #10
I would add the nut to your shifter linkage. Loctite is good but from experience I can tell you it will start to twist and squeak badly. I knocked the lever off the shaft and moved it up a cog to compensate for the added length.
Awesome build!
Thanks for the heads up. I'll keep an eye on it for now and tackle it during my next oil change.
Discussion Starter #11
I found a Spyker Seat on Craigslist. It was originally ordered from MSX125accessories.com, but similar seats can also be found on SteadyGarage.com. Here’s before and after pics:
The Spyker seat doesn't have the metal hooks (circled red) and you have to transfer the rubber bumpers (circled green) from the OEM seat to prevent it from being loose on the Grom.
I like that the padding is softer than OEM, but the style of the seat forces you to ride closer to the tank. I ride a little further back on the seat, so I’ll have to see how much I care for this shape once I get a chance to commute with it.
Discussion Starter #12 (Edited)
All ready for Killer Super Sunday 2017. I had @stiv_awd from IG install Michelin Power Pures onto some OEM front and rear gold wheels, Ohlins fork springs and fork oil, and a DID gold chain. The Grom feels so much better now. Those OEM tires were horrible in comparison to the Power Pures.
I also painted some of the bits on the Spyker seat. I used Angelus Paint, black and mustard. It's used for shoe painting and seems to be very durable. The yellow almost matches, but it's more of a dull yellow. I have to go back over it with some black to clean up the lines.
A friend helped me get my nerd on with some awesome Capsule Corp decals.
Discussion Starter #14
I added OTB turn signals. They’re awesome! They look great turned on or off. I’ve been wanting these since their release. They’re just as bright during the day, as they are at night. I classed up the Grom with the TYGA rear seat cowl from Steady Garage, side vents, and inner shrouds from Hard Racing. I also added an EJK fuel controller. I chose it for it’s plug and play ability. No computer. No fuss. No muss. They give you a forum discount, if you order from them directly. Butt dyno says it’s given the Grom a little bit of pep in its step. Lastly, I put in a Stebel Nautilus Horn I got from someone off Reddit. It fits snuggly behind the headlight. This thing is ear deafeningly loud. It screams, “Move bitch, get out da way. Get out da way bitch. Get out da way.” Picture time. Enjoy!
Can I ask you what you used to change the colour of the white flashing's to yellow on the Spyker seat? I have the same seat and don't really like them so would like to make them black and less visible.
Thanks
Davey
Discussion Starter #17
Thanks
Davey
Such a tasteful build, keep it up!
1 - 20 of 24 Posts
