1 - 4 of 4 Posts
Tire Pressure recommendation (baseline)? I'm about 160lbs suited, using Michelin Pilots 120 f, 130 r.
Pegs: any of you guys cut or grind you pegs to increase ground clearance? If so, how much and or provide pics so I have an idea how much to take off.
For now, I think this is it.
Thanks, in advance!
The track tire thread was some what helpful, while the others are not. I have read all those threads before, and is mostly applicable to those with street bikes. My post is directed specifically for track settings. If you had ridden the track, you would know that tire pressure differs quite a bit (tire compound and rider weight) vs street riding. Although, I do appreciate your effort in regards to my air pressure inquiry.
1 - 4 of 4 Posts
