1 - 14 of 14 Posts
The grom uses a more modern type motorcycle transmission in comparison to the older style used in the CT 70 and z50s.
The Honda nice 110 engines available in Thailand and Europe in the Wave 110 have been a really popular for tuning as they have the same mounting configuration as the z50, CT 70, trail 90 and trail 110 bikes as well as several other bikes. The difference is the nice engines are built a lot beefier, have a better charging system and are also more modern than the old engines. This makes them a great drop in replacement for all kinds of bikes.
Chinese and Japanese companies have made many copies of this design and some with improvements, but some come up short in the quality department.
Popular ones include:
YX series engines, GPX, Zongshen, Lifan, Daytona etc...
Many companies you see out there like piranha, stomp, SSR or Pitsterpro use one of the engines listed above, just with their name stamped into it and maybe a few slight design differences specified by the company.
The Grom although also a horizontal design does not mount the same as these engines.
The monkey bike scene over here in Europe is pretty big. Last year at one of the meets there was row after row of $10,000+ monkey bikes. A company here called TJR sells engines putting out upwards of 28HP if you can afford it and they are using the Nice engines as a basis.
This has a lot to do with the transmission, clutch and quality components.
This is a good link with some pictures of the Nice transmission
Nice Engine Headquarters Motor City Mini Trails
Grom clutch
Auto part Engine Automotive engine part Carburetor Automotive starter motor
The shift forks are of similar if not better quality than the nice
Auto part Machine Gear Engine Automotive engine part
The gears also use 4 lugs or hubs to transfer power
Auto part Gear Transmission part Hardware accessory
Timing chain and tensioner system. The problem with this tensioner system is I have heard reports of them not holding up when dual valve springs and a higher lift cam is installed. This is probably because it puts a lot more strain on the chain and idler pulleys.
Auto part Bicycle part Engine Bicycle drivetrain part Disc brake
So there you have it, it looks like it should hold up well in comparison to the nice engines,but we may not really know which are the weak bits until we get up in the 15+hp range
Discussion Starter · #5 · (Edited)
It really depends on the transmission. Some mini bikes have a 4 up shift pattern some a 1 down 3 up like my YX 140 and YX150. The shift pattern on bikes depend on the design. My MSX also does what you are describing and its normal.
On the ct70 see the two hooks that rotate the shift drum
Auto part Font Line art Steering part
Here is the grom's shift mechanism (top left) without the lever
Auto part Engine Automotive engine part Bicycle part Clutch
· Premium Member
If anyone has any more pics of any other Honda mini transmissions please post them here for comparison.
The only pics I ever took inside a Monkey case are of a blown Takegawa 5 speed tranny. I did not blow this one, I bought it like this and rebuilt it. Making 5 speed gears is difficult because the gears have to be made smaller and thinner with less material. This was the first generation Takegawa 5 speed and they were know to grenade. Takegawa made second generation 5 speed set that is much stronger, but still dose not last when installed in high horsepower motors. The Takky 5 speeds work great in a 110cc to 125cc engine. I still have the newly re-built 5 speed, unused in a box.
Auto part Gear Differential Rotor Automotive engine part
Auto part Gear Metal
This is showing the splines on a Takegawa Special Clutch. The cases are from a Honda XR50. The engine is shown in the bike below.
Auto part Engine Automotive engine part Carburetor Metal
I ended up putting a Takegawa close ratio 3 speed tranny in that engine. You can sort of see how much wider the 3 speed gears are, making them stronger. This 3 speed is a racing transmission and can handle the highest horsepower race engines without exploding. It is currently running in my custom Street Scrambler. The engine is all Takegawa 124cc Superhead, Special Clutch, etc. I built this mini bike from the frame up and it will blow away any Grom. Yes, even Big Chris's:playful:
Auto part Engine Automotive engine part Carburetor Automotive super charger part
Land vehicle Vehicle Motorcycle Car Motor vehicle
Discussion Starter · #8 · (Edited)
I think the Grom may also use a 5 disk clutch, but i didn't think to count the disks when i had it apart and its kind of tough to tell from the pics, could just be 4 though. Great pics and info by the way, thanks for posting. I would guess the stock grom gearbox should hold up pretty well under 20 hp. Nice bike by the way.
I think on planet minis I saw you had a street legal z50 with a YX 140. How is it running?
· Premium Member
All of my Z50 and clone mini builds are street legal. I have no use for a mini bike that is not street legal. The biggest I ever built was a 150cc with race head. I am the most proud of my Scrambler. It was featured on Motorivista and The Kneeslider magazines.
A few, but not all, of my builds are posted in my album here: ShapeShifter's Album: My Honda Mini Street Bikes
Hey, I know you!
How ya been, my friend?
Indeed! I'm well, besides my mental and physical conditions :)
Kids are growing, infernal combustion projects abound.
I hope all's swell with you. Good to see/read you're back on little bikes.
You don't know any Gromophile that would want a 280cc 4V build, do you?
We've forgotten the crackers!
1 - 14 of 14 Posts
