So this morning I went to go for a nice morning ride... it was a cold morning (maybe 55 degrees). I started the bike up and was confused why it was idling at 5500:shocked: rpms in neutral.
I took her for a quick spin around the block and when I came back the idle seemed more normal. So I figured it just needed to warm up.
When I got back from work though, it was 70 degrees and on startup it was doing the same thing. I tried to let it "warm up" but if anything it was creeping up to 6000 rpms. Well... I'm mechanically challenged so I broke out google and the diagnose was I should try adjusting the "idle screw". It took me 15 minutes to find the damn thing and it did work.
After tightening the idle screw all the way in, the engine will now idle at about 3200 rpms. I still feel this is a bit high, especially considering I can not tighten the idle screw anymore.
Any ideas on what could be going on? I am at 180 miles and did an oil change at 140. Oil level still looks good.
Mabruke
Mabruke
