1 - 2 of 2 Posts
I was driving my Grom and I downshifted while I was in third gear and reffed it at the same time it got stuck and started reffing like it was stuck in neutral just wanna know if it’s bad for my bike should I get it checked out ?
2015 MSX125 Honda Grom
I wouldn't say that's an issue if it was only in third. It'll startle you, for sure, because it feels like you hit a brick wall - but as long as you didn't dump it into second gear straight off redline in fourth gear it's fine on occasion. It'll add to the wear, but it's not unsafe in an isolated incident.
If you want to be super safe, check your oil clarity (just drain a bit into a cup, and top off whatever you took out if it's pretty clear). If it's dirty, change the oil. I believe the Grom uses 10W-30.
1 - 2 of 2 Posts
