1 - 15 of 15 Posts
I want to make steel braded front and rear brake lines for the grom. Can someone post pictures of the hose connection to the caliper, master cylinder, front and rear and measure the hose length from the center of the banjo bolt to center of the banjo bolt for the front and rear hoses please.
Ya'll rock!!
Im with you. Just cant decide with I am going to go with black or silver.
Discussion Starter · #10 ·
Oh, that was just for length of lines, as for bend angles of the fitting, yea ur gonna need a pic to get the exact bend.
Scale/ratio. Say on a picture the grom wheel is 1inch, u know the wheel is 12in. So from the picture if u measure a distance of 5in that would equal 60in @ real life scale.
Umm ya, thanks, that's why the title of the thread is called "Grom brake hoses, pictures please," not "what do you gess what parts I should use to make brake hoses for a bike I've never seen up close". Thanks, for your wisdom.
Approx scale I did was for the handbrake line. I guesstimating a 68in line, full throttle inc sells a 72in. So I am gonna order that and a magura 13mm master for the hb. Might even order that master for the front brakes too.
Already thought about setting up a hb on this thing. I had a braided ss on a full throttle junction for my first stunt set up. It'd be super easy to junction a line into a dual banjo on the caliper on the GROM I'm pretty excited!
That's a good idea on the front because I'm picturing dirty long supermoto style stoppies in the future!
Now you've gone to far. A 72" line. Are you out of your mind? I want some of what you're on. Then I'll just believe a grom is in my garage it's makes 165hp and goes 185mph, what oh that's my gsxr1000. Never mind.
Please sir, I am totally sober. Do by any chance you know what a hand brake is? Probebly not, well its a master on the left side of the handle bar that connect to a rear caliper. Crazy right? So yes there will be 2 levers on the left. And with what I'm planning on doing, there will be 2, yes 2 calipers on the rear disc. ;) of course I will need to manufacture an new bracket to accomodate the 2 calipers.
Discussion Starter · #15 ·
My apologies. Last night I was not totally sober. :wink:
1 - 15 of 15 Posts
