1 - 3 of 3 Posts
The Grom is great, but it needs more power. It needs more engine; approximately 2X more engine.
I was considering a big bore kit, but decided to go full 250 for reliability and power. There weren't any great how-to videos, so I made one that should explain everything nicely. Exact same steps for the 300 swap.
Let me know if you have any questions!
Nice video, thanks for sharing, all you need now is a custom made rack for your skim-board or boogie-board or mini-foil board for going to the beach. Nothing like good Southern Calif beach.
Monkey Father in Thailand sells a modified grom frame that aligns the 250-300cc swap engine the correct way with out the engine titling forward and the throttle body fitting under the frame, it comes with a radiator and the hose and hardware but it is pricey at around $1200+. The good thing is the chain sits in the right way and no extra sprocket to keep the chain from hitting the swing arm.
1 - 3 of 3 Posts
