1 - 3 of 3 Posts
Grip Puppies bring you added comfort, better throttle control and also reduces fatigue created by vibration. A soft, squeezable grip that simply slips over your standard rubber grip (no need to remove standard grip) and leaves you with a soft, squeezable, tactile grip that will give greater comfort to any bike as well as reducing vibration through the grip.
Only $18.99
:money:
Check out the Grip Puppies here!!
Are these even compatible with Grom grips? The site says they fit over grips 1.25-1.45” in diameter.
My OG Grom grips measured 1.19” (digital calipers) and appear to be too small per the manufacturer’s recommendation.
If they work without slipping, that would be awesome. I did a Bun Burner 1500 and my hands were buzzing for two days after I finished the ride.
1 - 3 of 3 Posts
