1 - 7 of 7 Posts
Going to a 37t sprocket rear. Do I need a chain with more links or will stock link count work?
thanks for the help
I would recommend changing chain and both front and rear sprocket all as a set. Using and old chain on a new sprocket is going to cause them to wear much quicker.
If you really don't want to do that, I would just change the front to a 14t (same overall gearing) and your stock chain will definitely fit.
Looks like someone likes to do a lot of wheelies with this sprocket setup, make sure to also get the modified oil pump so your wheelies does not starve the engine of oil.
Stock 15 and 37 aftermarket was very close to gearing with changing just to a 14 up front..Just the 37 tooth sprocket is a lot easier on the eyes looking at the bike.
Also MNNTHBX has a great looking silver sprockets in those tooth count very reasonably priced. Great guys also.
1 - 7 of 7 Posts
