41 - 45 of 45 Posts
you do know going -1 in the front is almost identical as going +2 in the rear, and its alot cheaper, were talking about $6 front sprocket or $40 for the rear
math
15/34 - 2.26
14/34 - 2.42
15/36 - 2.40
2.4 and 2.42 is pretty close IMO
im going -1/-2
14/32 - 2.28 close to stock, but i loose alot of spinning inertia on the front/rear sprockets, should be good, i did the same thing on my r1 i went -2/-2
and this is a common thing to do, even though people dont think its that common, you have to remember the bike makes 9hp on a good day, shedding some weight here and there will only help it
I went +1 on the front sprocket from the stock sprocket
Has anyone gone down 1 in front and up 1 or 2 in the rear?
Keen on better acceleration
I use mine to go to work and max speed i go is 70kmph (legally)
And my joy rides arent that fast around the 70kmph max 80. Very really will i get to 100 kmph
Thanks for the response.. might just go down 1 on front.. saves me getting new chain also
Sent from my SM-G950F using Tapatalk
I've done 13 and 14 in the front. For the price you can try both pretty cheap but higher speeds will be hurt with a 13, higher speeds with a 14 installed may be possible over stock gearing
41 - 45 of 45 Posts
