Hitting Mnnthbx up on a sprocket, curious if I will need a new chain or should it fit ok?
36 T rear sprocket will be no problem for the chain.Hitting Mnnthbx up on a sprocket, curious if I will need a new chain or should it fit ok?
Went two up on mine and have been very happy with it. Ran stock chain initially but once it stretched I replaced it with an O-ring.
Is your mileage accurate @ 25?Is your mileage accurate @360?
True but it is generally better for a chain to run with larger sprockets than smaller sprockets. Plus a $6 front sprocket leaves me with the crappy looking factory rear. I like the bling of my rear sprocket.you do know going -1 in the front is almost identical as going +2 in the rear, and its alot cheaper, were talking about $6 front sprocket or $40 for the rear
math
15/34 - 2.26
14/34 - 2.42
15/36 - 2.40
2.4 and 2.42 is pretty close IMO
im going -1/-2
14/34 - 2.28 close to stock, but i loose alot of spinning inertia on the front/rear sprockets, should be good, i did the same thing on my r1 i went -2/-2
and this is a common thing to do, even though people dont think its that common, you have to remember the bike makes 9hp on a good day, shedding some weight here and there will only help it
Pretty sure it is in the trans. If you change gearing and want to correct the speedo you are going to need to do it electronically. I used a Blue Monkey Speedo Healer on my jeep but I went from 30 to 35 inch tires so it was way off.A little question here.....
Where is the pick up point for the speedo MPH reading?
Here's 5 dealers off the top of my head. Sorry to the site supporters I missed.Where is everyone buying their front sprockets from?
