1 - 4 of 4 Posts
Dry fit using eastcoastfish’s 3-D printed mount. I’m using a mini fuse tap to get power, super easy. Why do people go into headlight bucket? Very close switched 12V?
Glowshift 10k white face analog tach is the way to go on a Monkey.
Discussion Starter #2
Well, it looks like I need the signal adapter to make my tach work.
On an up note, the yuminashi ecu is running my afr at 12.6-12.8 at WOT as measured on my Koso mini 3. Glad to know I’m not lean with the chimera intake and Hindle clone pipe.
Next is a ported head with bigger valves.
Works like a charm if you use the pink n green as coil negative instead of the black n white, no signal adapter required. I’m sufficiently confused. Going for a ride. Love the analog tach.
1 - 4 of 4 Posts
