1 - 8 of 8 Posts
Reading into the G-Craft swing arms. Goggle translate states that some of there swingarms have a stabilizer. What is a stabilizer? Is it the braced. Anyone read this better than me? What is T / S ?
60740 GROM/MSX125 swing arm STD 0cm without stabilizer (¥ 45,150) ¥ 45,150
Check stock pieces
60741 GROM/MSX125 swing arm STD 6cm without stabilizer (¥ 45,150) ¥ 45,150
Check stock pieces
60742 GROM/MSX125 swing arm stabilizer without STD 10cm (¥ 45,150) ¥ 45,150
Check stock pieces
60743 GROM/MSX125 swing arm T / S 0cm without stabilizer (¥ 53,550) ¥ 53,550
Check stock pieces
60744 GROM/MSX125 swing arm T / S 6cm without stabilizer (¥ 53,550) ¥ 53,550
Check stock pieces
60745 GROM/MSX125 swing arm T / S 10cm without stabilizer (¥ 53,550) ¥ 53,550
Check stock pieces
60746 GROM/MSX125 swing arm T / S mini 0cm without stabilizer (¥ 50,400) ¥ 50,400
Check stock pieces
60747 GROM/MSX125 swing arm T / S mini 6cm without stabilizer (¥ 50,400) ¥ 50,400
Check stock pieces
60748 GROM/MSX125 swing arm T / S mini 10cm without stabilizer (¥ 50,400) ¥ 50,400
Check stock pieces
Yes 60749 GROM/MSX125 swing arm STD 0cm stabilizer (¥ 55,650) ¥ 55,650
Check stock pieces
Yes 60750 GROM/MSX125 swing arm stabilizer STD 6cm (¥ 55,650) ¥ 55,650
Check stock pieces
Yes 60751 GROM/MSX125 swing arm stabilizer STD 10cm (¥ 55,650) ¥ 55,650
Check stock pieces
Yes 60752 GROM/MSX125 swing arm T / S 0cm stabilizer (¥ 64,050) ¥ 64,050
Check stock pieces
Yes 60753 GROM/MSX125 swing arm T / S 6cm stabilizer (¥ 64,050) ¥ 64,050
Check stock pieces
Yes 60754 GROM/MSX125 swing arm T / S 10cm stabilizer (¥ 64,050) ¥ 64,050
Check stock pieces
Yes 60755 GROM/MSX125 swing arm T / S mini 0cm stabilizer (¥ 60,900) ¥ 60,900
Check stock pieces
Yes 60756 GROM/MSX125 swing arm T / S mini 6cm stabilizer (¥ 60,900) ¥ 60,900
Check stock pieces
Yes 60757 GROM/MSX125 swing arm T / S 10cm mini stabilizer (¥ 60,900) ¥ 60,900
Check stock pieces
60908 GROM/MSX125 swing arm only OP fender stay attached processing
T/s is true square. I wish I had better pics of what they offer and on a bike. 60908 is an additional piece to hold on the fender
Actually T/S stands for Triple Square. It is the type of tubing that they offer which is stiffer than the STD (standard) tubing. You can get it with or without the stabilizer which is the hoop that goes underneath that adds some rigidity. I have used the STD (Standard tubing) 0cm (stock length) without the stabilizer. It was a nice quality swingarm.
Yup, I got autocorrected.
Does yours have the fender stay?
Reactions: Fun Size
The one I had did not. It wasn't available at the time. I have since replaced it with the SP Takegawa unit which does have the fender stay.
Bushes. I found the part # for the bearings, waiting for GoGrom to get back to me on it.
(Honestly, after just installing the swingarm, I'm prolly just gonna roll the bushes. That job sucks a bunch)
PN is 90 606 pivot point somethingornother
1 - 8 of 8 Posts
