1 - 8 of 8 Posts
[HR][/HR] The Grom has less than 200 miles on the odm and this morning I decided to check the compression since the my adapters for my compression tester came in and I did not have a small 10 mm spark plug adapter.
I checked the compression with both of my testers and I got between 100-105 psi with a stone cold engine with no warm up.
setting up the test with my old tester
second tester reading 100-105psi
testing heat on the exhaust, heads and cylinder, warmed up the engine a bit
head temp around 160-171 deg F
cylinder temp 160-180 deg F WOT
exhaust temp taken from the pipe leaving the head 311-337 deg F WOT
Guys,
Don't panic about the compression. It's about 160 PSI stock. The Grom has a ACR,(automatic compression release) on the exhaust rocker. Spinning the engine activates the weight on the cam and opens the exhaust valve just slightly. I don't know why they don't mention it in the shop manual. Using an intake rocker on the exhaust fix's the issue, and you get 160 PSI. It's there for starting.
Brian
Discussion Starter · #4 ·
Guys,
Brian
Very good info to know, thanks BrianS
Guys,
Brian
I wonder if that's the reason why the exhaust has a different sound during cold start and once it's built up some heat, the exhaust sound changes?
1 - 8 of 8 Posts
