1 - 20 of 37 Posts
Discussion Starter · #7 ·
Hey Alan, did the levers activate the front brake lights? I bought the same ones and had the issue. If they work I will take them for sure.
The brake lever fit good and it did activate the brake light. The clutch side though installs a bit loose but you have to some play in it otherwise it will bind.
Sorry I should of asked about fit and finish before I said I would take em... ill have to pasd thank you though and glws
Sent from my SPH-L710 using HondaGrom.net mobile app
Everything is still forsale. First come first serve.
Discussion Starter · #15 ·
Still got some stuff forsale
Hey Alan, I think I will grab the levers from you. Any chance you can compare the part on the front brake lever that activates the brake lights to the stock one in terms of how long it is? If it is close to the same I will grab them. I purchased the same levers from ebay and mine push the activator out of the way so it actually makes the lights stick on or they don't work sometimes.
Discussion Starter · #19 ·
mine are the same length as stock. i had them on for one day and never had a any problems with the brake light staying on or sticking.
1 - 20 of 37 Posts
