1 - 2 of 2 Posts
so anyone know or can give feedback on the front brakes? anyone got any experience with the brembo 84mm? i already got a magura 15mm radial master to swap out asap. but any ideas if rigging a 84mm brembo on the front will be better than the stock slide ?nissin? caliper? not sure of the diameter differences, but from the stock dual one sided slide type pistons to single double sided brembo pistons should be better right? i hope that made sense.
I know most of the Thai swap to Brembo 'rear' calipers on the front asap. I don't think the front is overly bad, but the hose is very soft, so it has a spongey feel. I'd recommend new lines and sintered pads first. Should make a big improvement.
1 - 2 of 2 Posts
