1 - 16 of 16 Posts
I had to replace the front tyre the other day in preparation for my Groms MOT (it passed with no issues) so I changed the wheel, bearings, and brake disc among other things. Obviously to swap out the wheel I needed to jack the front of the bike up. And to do so I had the rear on a paddock stand and used a scissor lift with some wood under the engine to raise the front. While this worked I wasn't happy with the setup, it wasn't as stable as I would have wanted and I was concerned that the points on the engine I was using were not the strongest. However it worked. But in the future I will need to lift the front higher and for longer in order to remove the forks to work on them, and thus I need a better or more convincingly secure way of jacking up the front of the bike, and so to my question...
How do you lift the front of the bike safely?
I get two ratchet straps and loop both around the triple tree and then around the rafters in my garage. The just ratchet it up evenly.
I have a triple tree stand but for some reason it doesnt work with the grom.
Wait what is with your name? Are we gonna have a problem here?
Same thing, I regularly hang my Grom, both for front or rear.
It was nice knowing you LordSquirrel... :shocked:
Come at me bro
Now that was funny.....
Back on topic.....I have also used a A-frame ladder positioned over the front end of the bike, and used two straps connected to the ladder to hold up the front end from the handlebars.
Now I'm not saying you should be, but if I were you I'd be worried...
As for the suggestions, hanging from the rafters or an A frame ladder isn't going to work for me. Mainly as I don't have rafters or a ladder, but also I don't like the the idea of the bike swinging around from a couple of straps (I've seen a video of someone doing this on line, and it didn't look very secure), plus the lifting points might also be something I'd want to remove. Any other ideas out there?
I only have a back yard so no rafters to use, when I took my fork legs out to change the oil I put a wooden plank across two wheelie bins and tied the bike up that way.... bit of a bodge but it was secure and worked as a one off.
I haven't had good luck with the head stand. On my cbr it was solid, but on the grom i had to take off the headlight (no problem) and it just would not hold it. Maybe it's just the cheap stand I have.
Discussion Starter #14
Build one like this so you can work either the front or the rear wheel.
Looks like I'm going to have to dig the welder out and fabricobble something up like that, was hoping to avoid it though.
^^ that, or you could have a look at Abba stands, they have those for the Grom / MSX even though it's not listed.
https://abbastands.co.uk
Just had a look at their site and they have the MSX listed, plus I have a couple of Abba stands kicking around. However they state that the foot pegs need to be folded up which is a problem for me as I have Tyga rearsets on mine. Have you got the adaptors, if so where do they lift from?
Discussion Starter #15
Well I was going to do as obijuanito has but then as I was starting to line things up I found some extra bits from the scissor lift and well I think they are intended for frame rails on cruisers but worked for me...
1 - 16 of 16 Posts
