What are my options for stiffening up the fork on my 2021 monkey?
I have had some stiffer shocks on for quite a while and the softer front end is getting noticeable enough that I'm thinking about going through the effort to install some stiffer springs.
Is there a way to add some preload to what's in there? I see some discussion about adding some oil but I'm wondering how much that actually helps. I also see that if going to a heavier spring you should switch to a heavier oil. Is moving to a heavier oil going to have an effect on the seals?
Thanks.
Edit: I should add that I'm not really interested in adjustability. I just want something a bit stiffer and was hoping I could get away with not spending the money on an Ohlins setup.
Thanks.
