1 - 8 of 8 Posts
So yesterday I installed a fender eliminator and prior to installing it the rear foot brake light was working. After installing it the front brake lever activates the light fine but the foot brake doesn't. Any ideas as to why this is happening? I have not adjusted the switch as it was fine prior to this.
It's most likely the switch, I had the same issue on both my groms when they were new. Adjust it and you should be good to go.
Thanks for your help it seems that is a incredibly sensitive switch it only works within a range of about a turn in a half any thing more or less that that it doesnt work.
It's a threaded unit with two nuts that you twist and tighten until the brake works properly. Just look at it, it'll make sense.
1 - 8 of 8 Posts
